switch mounting - front right in dark myrtle and swing
4 Attachment(s)
I've bitten the bullet and ordered a brand new one of these to match the others I got from A8 parts - this one, not surprisingly being used and from the driver's door, is not quite up to the condition of the others
The exact part number is 4d2 959 522L KCK and is described as Dark Myrtle finish with Swing for the insert bit to match the lower handle area. There are small dents along the edge of the hand hold area, nearest the drivers seat, and along the rear. The front section is in very good condition and the symbols are all clear and unmarked. The Swing coloured section has some staining in the corners that you can't really see but does have quite a lot of marks along the rear. Hopefully the attached pics will be a better indicator of condition. I have all the switches which I can throw in as well - I removed them all and cleaned them as I intended to use the ones from my car and just keep them as spares. £20 including delivery if anyone's interested. Adrian |
