-   D3 - Engine Bay (https://forum.a8parts.co.uk/forumdisplay.php?f=44)
-   -   Diesel in the Oil (https://forum.a8parts.co.uk/showthread.php?t=7250)
Norrs2 26th November 2013 10:38 AM
Diesel in the Oil
Folks
Bit of a strange one! My mate has a 2005 facelift 3.0TDi (non DPF - car has dont 130k miles) and every 4,000 miles or so (he's doing a big mileage) there is Diesel getting into the Sump to the point he is having to drain the oil and refill to stop it getting too full.
There is no fault codes for the Injectors (Injectors have been suggested as the fault) but also, if the Injectors were spraying in so much fuel that the bores are being washed with Diesel and getting into the Sump, surely there would be loads of smoke, which there isn't!
Any other suggestions please?
TIA
Adrian E 26th November 2013 12:03 PM
Breather system or bore wear/stuck rings would be my only suggestions - can't be many other ways for diesel to get into the sump if you've already excluded the injection system?
ainarssems 26th November 2013 08:16 PM
Short journeys with cold engine will get you some diesel in oil. if he mostly drives couple of miles at the time it could very well be that.
snapdragon 26th November 2013 08:33 PM
Diesel injector body/ies has/have started to leak? between sections from the body seals which would spray straight into the valve gear chamber and dilute the oil.
http://www.ebay.co.uk/itm/2006-Audi-...-/321221360079
Norrs2 27th November 2013 08:01 AM
Hi Adrian
With that milage I'd be horrified to think there was bore wear on an Audi engine?
The Injection 'system' is not totally excluded, it's just been pointed out that if it was due to exessive fueling/spray it should be smoking which it's not.
I too wondered about Breather somewhere, but can't think what breather that could allow Diesel into the oil that could be!
Cheers+++
Norman
Norrs2 27th November 2013 08:02 AM
No mate, his normal skip to work is over 50 miles, so shouldn't be due to that.
Norrs2 27th November 2013 08:05 AM
Very interesting!!! A Mechanic friend implied something like this, but we could'nt get our head round how this could happen.
Does the body of the Injector pass through the Rocker area 'naked'?
snapdragon 27th November 2013 09:31 AM
Yes, the injector passes through the valve cover, through the 'rocker area' naked, and then into holes in the head with a smaller hole at the bottom for the tip to spray into the combustion chamber.
The injector is made of 2 or 3 sections crimped together with seals.
I have heard of the bodies of BOSCH piezo injectors leaking on other cars but not Audis, but as our cars get older it is more likely I suppose.
http://www.youtube.com/watch?v=O_Y3dM8ZApo
davesA8 6th February 2014 06:26 PM
I know we are talking Audi here! but Bmws suffer from the High pressure pump leaking into the crankcase! which is usually the seal on the high pressure pump which fails, just a thought? cheers Dave
Delboy 6th February 2014 06:58 PM
+1 what snap dragon says
