Hi,
What offset are they please? Thanks Rich +++ |
Haven't a clue, how do I tell? They fit my D2 fine and came from a D3 so they should fit any A8
Hi, they are not for a A/S8, but possibly an A6 2006, same bore of 57.1 and same PCD of 5 by 112,just the offset dimension required
Thanks |
Right I've just finally gotten round to moving them into the garage, so on the rear it says 19x8J for the actual wheel size, and ET 35. Hope this helps. :)
Yep ET 35 is the offset +++
ET35 will bring them 13mm to out comparing to stock D2 S8 18x8J rims with ET 48. I am running merc rims at the moment with ET35 but also wider 9" and this way they are 25mm more out on the outside and the same place on the inside
