Steering column clunk and wandering
car was in having the bumper fixed from when my wife had an argument with a supermarket car park - the Audi lost
The mechanic mentioned that when he was manoeuvring the car he could hear a clunk from the column and then on test drive it was wandering and needs constant correction His suggestion was that maybe a UJ was worn in the column? Does the A8 have UJ's in the steering column? if not does this mean a new column needs to be fitted? How big a job is this? |
also if I go through a puddle with the nearside front wheel I lose PAS and the steering gets really heavy - no pas
PAS pump is belt driven, water could be getting on the belt causing it to slip. If I recall on LHD cars the pump is down on your nearside.
It is a RHD car - and I asked the garage to look at that and they said the belt was OK
1 Attachment(s)
My S8 has the same symptoms, play in steering and clunk when going over bumps. And its just had a new front suspension and all the suspension arms checked professionally so its not those.
I was searching on quattroworld for answers and they suggest adjusting this, as per ElsaWin original procedure. Worth a try as its a free fix. Elsawin: Adjusting power-assisted steering box Adjusting power-assisted steering box Two mechanics are required to perform adjustment. Adjust with engine switched off. ‒ Lift vehicle on lifting platform. ‒ Wheels in straight-ahead position. ‒ By turning the steering wheel back and forth (about 30°around centre axle) a rattling noise will be heard if there is excessive steering play. ‒ → The second mechanic should carefully turn the adjustment screw (arrow) until the rattling noise can no longer be heard inside the vehicle. ‒ Carry out a test drive. ‒ Ensure that when manoeuvring or negotiating corners the steering automatically returns smoothly to the straight-ahead position. Adjust setting if necessary. http://forum.a8parts.co.uk/attachmen...1&d=1388923838 |
thanks I will get them to try that - I have checked nearly everything else
My S suffer from play when engine is on and nothing while off.
I'm just about to ordet a new steering rack from Germany. Maybe i should try this trick frist. :) |
Steering rack replacement is a serious pain in the ass, fingers crossed for you it's not the rack
I know had it done a few years ago - terrible job :-)
My garage said there was no screw inside the bolt? when it says screw does it mean turn bolt? and it is a typo or have I and adjustment screw missing? |
