-   -   D2: Tool for retracting brake pistons? (https://forum.a8parts.co.uk/showthread.php?t=7446)
notorious 9th January 2014 07:12 PM
Hello all,
I'm going to change my front and rear brake pads soon.
Doing this myself for the first time.
I understand the trickiest bit is to retract pistons.
Should I purchase any specific tool, like a clamp, to retract pistons 'properly'?
Any advise will be appreciated.
P.S. My car is normal FL A8 with floating front callipers. Non-S8 version it if helps.
PsYcHe 9th January 2014 09:23 PM
Fronts are standard fare, but the rears need the tool that winds them in.
Should be under 20 quid from your local motor factor and makes the job sooooo much easier.
notorious 9th January 2014 10:08 PM
Thanks for reply.
Here is write up for exactly my model of front brakes: http://www.audipages.com/Tech_Articl...rakestwin.html
In that writeup the guy retracts pistons with two screwdrivers. Is this correct? What if pistons are a bit difficult to shift? Screwdrivers can damage some rubber boots/seals if they are there.
Or perhaps this tool will help? http://www.ebay.co.uk/itm/449774-Dis...-/281234890728
Is this correct kit?
http://www.ebay.co.uk/itm/BRAKE-CALI...-/181282486891
Apologies for so many questions :) The last thing I want is to put car to pieces and then realise I don't have the tool :)
Goran 9th January 2014 10:53 PM
Hi Sergey,
I did this job myself on the rear brakes, I used a simpler kit like this:
http://www.machinemart.co.uk/shop/pr...brake%20rewind
One thing I can say, the handle on these kits is too short, for one of the calipers I had to put a bit of pipe over the handle to get more leverage to get the turning started. Once the caliper piston starts turning its a bit easier, but not much.
The rear brake procedure:
http://www.audipages.com/Tech_Articl...earbrakes.html
ainarssems 10th January 2014 06:10 AM
I have one like this for rear http://www.ebay.co.uk/itm/Brake-Pist...item485860834d
Front does not need any special tools
PsYcHe 10th January 2014 09:59 AM
That's almost identical to the one I have.
If you've got two pistons on the front, they should go back in together.
I usually use a long spanner across the two and just squeeze, usually works, or put the wind back tool on the spanner and use it for some extra force.
ulfilias 10th January 2014 11:31 AM
Hi There,
I have the same Laser one too. I tried it without for a few hours and caved years back. They fit other models too and have been useful to lend to people. I wouldn't even atempt it without the tool as the pins lock in, the presure is applied and even if you can do it with a clamp and bits, it shortens the job by tonnes and makes it relatively easy.
The bar is as said way too small, but the shaft is hexagonal and forged and takes a large socket which is the way I do things.
Lee
notorious 10th January 2014 07:17 PM
Thanks for all your replies.
I purchased this model:
http://www.ebay.co.uk/itm/BRAKE-PAD-...-/121194419292
It has hex end for socket or spanner.
Hope it will work.
Dezzy 13th January 2014 07:58 AM
I use pipe grips and a G-Clamp :o
thebluewhale 8th February 2014 10:22 AM
Why does that not surprise me Dezzy Haha
