-   D3 - Common Faults (https://forum.a8parts.co.uk/forumdisplay.php?f=67)
-   -   57 plate fault code (https://forum.a8parts.co.uk/showthread.php?t=7481)
B17NKA 16th January 2014 06:49 PM
57 plate fault code
How do everyone
Does anyone know what engine fault code 06256 means,car is a 57 plate A8 3.0 Tdi
Car runs and ticks over spot on ???
Code does not put any error lights on but keeps coming back on diagnostics
Would like to know what it is for peace of mind
Cheers Andy
mannyo 16th January 2014 08:15 PM
from a previous thread,
006256 - Transmission Mount Valve 1 (N262)
You need the rest of the fault code.
and here.
http://www.tyresmoke.net/forum/topic...t-valve-error/
B17NKA 16th January 2014 08:26 PM
Thank you mannyo I have read the thread attached still none the wiser like,can I live with it or do I need to get it repaired
I will get the rest of the code,I know it said something about upper limit exceeded
CheerscAndy
snapdragon 17th January 2014 08:03 AM
It's a rubber mount on the gearbox which can be made stiffer or softer depending on what the engine and gearbox are doing and it has blown so is just a dumb rubber mount now. The symptom would be a small reduction in refinement.
B17NKA 17th January 2014 05:33 PM
I will look at having it replaced whilst car is under warranty
Regards Andy
