S8 (D2) Control Arm Supension Kits - Experiences?
Per title, any experience with after markets front control arm kits as suspect VAG will be more than car is worth !
Yes, I replaced all of mine with an after market kit. And I know I'm not alone. There's a thread on here somewhere, but I'll try to dig out the make and supplier at the weekend
Ill have a search thanks. Assume yours are still all good after X miles ? I have read the ebay ones can last a year at best..
My Lemforder arms (front n/s and o/s upper front and rear control arms - that's two per side at the top) were £54 and £38 each - £92 per side/£184 all in - provided from TPS to my independent fitter. Fitted 10 months ago and still tight. Most will swear by Lemforder or equivalent OEM but some will say, go cheap as you may not need the long life. Horses for courses.
Thanks David, was that with 20s on an FE as i know both lower arms are different from factory as is the wheel bearing housing for cars running 20s ex factory, which is going to make them more expensive i fear, groan..
EDIT i just re-read and see you replaced uppers only |
If you're planning on keeping the car don't buy the cheap sh1te because you'll be changing them within 2 years.
Lemforder or Meyle HD are probably the way to go. +++ |
Mine were Meyle from ebay, and I bought a full kit. But despite telling them car details, 2 of the arms were still the wrong type and had to be returned. had them on about 6 months and all seems OK so far.
Haven't replaced these arms on an A8, but have on my B5.5 Passat. Used Lemforder parts, and best price I found was from CarParts4less. The arms were excellent quality, and appeared to have VW Audi logo's ground off.
I used the cheap ones from german e-bay about £120 for a set, after about 4 years and 14k miles shock absorber bush started looking poor, still passed MOT without advisories but I decided to change lower straight arms anyway this time with Meyle HD, about £75 for the pair. Rest of the arms and bushes are still fine. The shock absorber bush did have hard life with 19" and 20" wheels and high tyre pressures of 42-44 PSI and I do not slow down much for speed bumps or pothole's so I cannot complain much
Dezzy have had 2 sets of cheap e-bay arms each lasting 40k miles with 18" wheels. I have fitted fair amount of cheap e-bay sets to A4's and A6's, the arms seem to last well but with track rod ends from the set there is 50:50 chance they will fail after 10k miles or so. |
