audi s8 d2 10x20 all round
hi all, I'm currently running a staggered set up on my audi s8 d2 using 8.5x20 fronts and 10x20 rears et35,looking to run 10x20 all round,heard it has been done with no issues, but what soze tyres do I use,or do I use the same as the rears now for the fronts at 275/30/20? I don't mind having the stretch look,as I am in the process of getting air ride fitted to the car,so want the low look with clearance as well.
any input be great or anyone who has done this be much appreciated |
If they are all 275 30 20s then you will have no issues with the quattro as rolling radius will be the same front and back so I would go with that.
Im not sure if D3's can take 10" wheels at the front my best guess would be yes but on D2's you start to get clearance issues. +++ |
well I did try it today with one of my rear wheels very close I mean millimetres off the strut at standard height jacked up in the air,i have seen it done but personally I cant see it doing it and not rubbing mate
Did you take an pictures of the test fit? |
Agree with CLKFAN
255/35/20 is perfect, I had that on my a8 D2 with KW2's and 10X20 ET 35 |
Correct, but 5mm less on the inside. Dont think its gonna be an ussue but i would check just in case.
2 Attachment(s)
I put the new tires on today. I purchased Dunlop Maxx GT 255/35-20 ZR. In fact the only tire brand available in this size where I do my shopping. It has been an increased demand for this size lately they said. This size gives a stretched look on the 20x10 RH NAJ rims, but I found it easy to accept this as I just love these rims. I have ET40 and still the rubber is slightly outside the front fender, but totally acceptable. ET35 will go even 5 mm further out so I'm happy with my ET40 rims.
The tire has a rim protection profile which fluctuates with the rim itself, hardly any practical protection but it looks ok. It leaves an open crack due to the stretch. Overall I'm satisfied. The handling is very accurate and firm with this setup(sport suspension). See for yourselves! |
Looks great! +++
I've always like that design of rims |
Hey folks am back got the motor back on the road today,was in two minds to sell it and but we're back on the on the road again,still trying to find someone to air ride it so can drop it low
