-   -   Audi S8 D2 Facelift correct size discs?? (https://forum.a8parts.co.uk/showthread.php?t=7739)
H24k 4th March 2014 09:33 PM
I have both an early 1999 facelift S8 and a later 2000 facelift, the difference between cars seems to be the badging on rear and front, the earlier car has the same badge as the pre facelift S8 and also the same badge on instrument cluster, but it also seems that the brakes might be different as ive just bought a set of mintex 280mm for the rear and they dont fit which seems to indicate that only 269mm will fit? However my other car seems to be ok with the 280mm, Im wondering if the pre facelifts had 269mm at the rear and this was carried on in the early facelift models and then upgraded to the 280mm later? Does anyone know?? Thanks
SilverS8 5th March 2014 09:56 PM
My FL S8 was built 10/99 and has 280mm rear discs.
Architex_mA8tey 6th March 2014 07:13 AM
I wouldnt be at all surprised if Audi "used up the old stock" first as there are countless other examples of where they have done that on the change from PF to FL :rolleyes:
Adrian E 6th March 2014 07:17 AM
If you have a PR code in the service book 1KE then it's definitely 269mm rears and if it's 1KW then should be 280mm :)
I suspect it's related to front brake setup as there's no VIN series associated with the choice
johnny_quattro 9th January 2016 05:26 PM
Old discs on FL
Reviving an old thread, I've just checked on my early FL model (2000 A8L) and I have the following codes:
PRCode: 1KE = Disc brakes rear
PRCode: 1LX = Disc brakes front
So it looks like mine are the smaller 269mm jobs out of the Audi parts bin.
ainarssems 9th January 2016 05:48 PM
269mm rear, 323mm front so the most common size for FL D2 A8Q, only S8, W12 and armoured versions have bigger on D2
