ABS light....and, a little later, then engine light...
All,
The abs warning light came on on Friday, but with no tell-tale accompanying abs activation / juddering when braking at low speed or coming to a stop normally associated with a failing or dirty sensor. I had a sensor replaced about 18months ago for that very reason. Anyway, more worryingly, the little engine picture light came on a little later. Hmmm, I thought. :Confused: I had been rather rigorous with my new under car / wheel arch nozzle on my Nilfisk, and wondered if I had dislodged a connector. Anyway, front brakes needed a check over and retorque after fitting my newly refurbished calipers at the end of last year, so I did a strip down and clean up on both fronts, and reassembled. All good again yesterday (I unplugged the battery for a while as well), but back in car today, abs light has relit, and a little while later, the engine light has come on to join it. Any ideas, without VAGCOMming it? Brakes are working great, by the way. Thanks in advance, Mark |
If all drives well, and the only issue seems to be warning lights then Vagcom really is the only accurate way to tell whats going on.....
Am I right in thinking that combination of fault lights suggests an ESP fault?
scan is the only answer for a definitive answer unfortunately |
