-   D3 - Lights (https://forum.a8parts.co.uk/forumdisplay.php?f=48)
-   -   headlight range defective (https://forum.a8parts.co.uk/showthread.php?t=8502)
Palmer 24th July 2014 07:55 PM
This error just shot up on my dash. Turned it on and off and was fine. Should i be worried??
Somerandomguy 24th July 2014 08:29 PM
Could be as simple as one of the ride height sensors on its way out, VCDS will co firm and really easy to change if it is.
tersono 25th July 2014 10:31 AM
Had the exact same thing recently. Started off with the headlamp range light appearing then going away again. A couple of weeks later it came back on, but this time with the air suspension warning light. As said above, it turned out to be the ride height sensor.
Palmer 25th July 2014 10:48 PM
Ill get it scanned then cheers folks
Adrian E 26th July 2014 08:04 AM
When you get into VCDS you can look at measuring blocks which show the voltage at the sensors - if one of them is 0v or varies inconsistently with ride height (requires an assistant to bounce each end of the car) then it points to the faulty end. Can just be a dodgy connection though
