-   -   Steering wheel controls (https://forum.a8parts.co.uk/showthread.php?t=8504)
jnelis 24th July 2014 11:01 PM
Hello all, Owned my D3 S8 06 plate for about 6 weeks now. Love the car and I knew of a few issues when i bought it. Mostly minor cosmetic items. However I have since discovered that the steering wheel controls don't work! ie unable to adjust volume, and switch between information screen etc and operate paddle switches.
Maybe some of you guys have experienced similar issues? and can point me in the right direction of where to look for the problem?
Any help and advice as always greatly appreaciated.
cheers,
John
ScottD3 25th July 2014 08:52 AM
Do you have VCDS?
Get that plugged in, check for fault codes and make sure its programmed correctly.
Had the same issue on my dad's car and the steering controls was not programmed.
jnelis 26th July 2014 02:40 PM
Hi Scott,
Thanks for your reply. I will look into this. I know a great Audi technician from owning 3 different models prior to the S8. I think it's time to give him a call.
I will update the results.
Cheers,
John
