Ski Bag??
I gave my interior a thorough going over and discovered a long 'bag' tucked away behind the rear armrest. I'm assuming it would be for skis.
The problem is, it won't fit back in, and I can't close the hatch. Is there a easy solution for this? |
If you have the ski bag, you'll also have the hatch in the boot, you could open that to give you some space to try and tidy it up for folding back in.
I would have this problem in my B5 every time any one got in the back seat and said 'what's this for'. No quick solution really, just fold neat and tight. Handy for collecting timber from B&Q though.
And that sometimes postpones so many DIY projects which I can't be bother to do later if I can't do it right now |
I'm not sure how the D3 ski hatch is constructed, but I retrofitted it into my (FL) D2 and decided to leave the bag (elephant condom!) itself off - it's stored under the boot floor next to the spare wheel.
If it's similar (might be identical) it just clips back into place with plastic lugs around the rim. Very easy to fit and remove, takes seconds. To do this open the cover in the boot and just push the frame into the channel around the hatch and the clips engage. Obviously this involves reaching deep into the boot and getting some decent light source so you can verify you have it all the right way round and right way up. |
I have the ski bag and surround off my scrapped D2 if anyone is interested - currently on ebay
http://www.ebay.co.uk/itm/3012895328...84.m1555.l2649 |
If you look carefully at the frame on the tube and where it fits onto the method and orientation should be obvious. |
iirc the whole D3 hatch mechanism removes quite easily, much easier than the D2 that requires the back seats out.... I discovered this when transferring the fridge from my 4.2 Tdi to my S8 (which Oli promptly negotiated back!) as it was a very easy clip in / clip out....
If it's that easy on a D3 it might be easier to remove it all to refit/reorganise the actual bag. (On D2 I found it easier to fit the frame without the bag there) |
