-   D2 - Engine Bay (https://forum.a8parts.co.uk/forumdisplay.php?f=20)
-   -   OEM spark plugs - D2 S8? (https://forum.a8parts.co.uk/showthread.php?t=8788)
Zip 21st September 2014 01:49 PM
I know I'm being dippy, but can someone tell me the exact make and model of oem or audi recommended plugs please. Audi want £220 to change mine :ROFL:
Cheers Zip
ainarssems 21st September 2014 02:54 PM
I don't think there is one make, it will change depending who Audi or VW had contract with at the time of manufacturing. So Bosch might be making the part for couple years, then they get better deal with Beru and who will be making the same part number for couple of years, then they can change it to somebody else or switch back to Bosch. Same with many other parts like brake pads depending of year of manufacturing the same part number can be made.
Goran 21st September 2014 08:11 PM
Should be Bosch Platinum for a facelift S8 (unless there are some new better ones that replaced them recently?)
FGR6KQE
101000054AD
They should look like this:
http://forum.a8parts.co.uk/showthread.php?t=8275
If I remember correctly several good independents recommend these OEM plugs too,
some other makes like NGK may run hot. Hope I'm not spreading any bad rumours.
ainarssems 21st September 2014 08:34 PM
Those are not Platinum
Adrian E 22nd September 2014 07:35 AM
Go to local TPS and get them to look it up for you - they should have them on the shelf to confirm what you are getting in the part numbered box :)
notorious 22nd September 2014 08:40 AM
Buy genuine spark plus from TPS our Audi, but change them yourself. You'll need a basic torque wrench and some basic tools. All that can be purchased from Halfords. All torques are documented in ELSA. Changing plugs is an enjoyable work.
Adrian E 22nd September 2014 09:00 AM
For ease:
AQH, AVP, AYS and BCS engine codes use 101 000 054AD plugs made by Bosch according to Etka and are currently £15.89 incl VAT each - my last plug change 4 years ago quoted them at about £12 each.
For AQG, AQF, ARU, AKC, AUW and AVN engine codes it's 101 905 615A at £15.43 each
ElsaWin doesn't go into any detail on a plug change, but does state that the plugs should be torqued to 30Nm
ElseWin
Checking ignition system
Technical data for ignition system
Engine code letters
AQF 4.2 L 228 KW / AUW 4.2 L 228 KW
ARU 4.2 L 175 KW / AVN 4.2 L 175 KW
AQG 3.7 L 191 KW / AKC 3.7 L 191 KW
AQH 4.2 L 265 KW / AVP 4.2 L 265 KW
Ignition timing is determined by the control unit.
Ignition timing cannot be adjusted.
Ignition system
Individual coil system with 8 ignition coils connected directly to spark plugs via spark plug connectors (common component ignition coil and performance output stage).
Spark plugs
Spare part number and manufacturer description
see spare part catalogue
Tightening torque
30 Nm
Firing order
1-5-4-8-6-3-7-2
ETA: According to Bosch site, the recommended plugs are FGR6KQE which Euro Car Parts list under 'OE quality spark plug' with a Bosch picture, but then state may not be the brand supplied. Be worth ringing and asking if they are that part number and Bosch as they're quoted at £6.72 each incl VAT!
Zip 22nd September 2014 09:57 AM
Thanks for your help, gents. I'll let you know what I end up with...
Z
Adrian E 20th May 2016 10:13 PM
OEM from TPS are now £17 each before any discount!
Euro car parts have the same Bosch parts (although my reg based search brought up the wrong ones!) for £7.39 each and this weekend with an extra 20% off I've bagged a set of 8 for less than £48!
Search for ECP part number 408330080 to find the right ones
Almost £90 difference :ROFL:
Goran 20th May 2016 10:34 PM
Tempting at those prices. Looking at them a bit, I am worried, why are the ECP plugs with brass thread in the picture when genuine Bosch ones seem to have a silvery (Nickel coated?) steel thread.
