Installing S2T Paddle Shifters
21 Attachment(s)
My new paddles finally arrived and below is a quick install guide.
If you are interested in buying a set, contact an amazing and extremely helpful guy Tony by filling a contact form on www.tgdperformance.co.uk http://forum.a8parts.co.uk/attachmen...1&d=1412280200 First remove the caps on the back of the wheel to gain access to 2x big torx bolts in order to remove the airbag. It is recommended to keep ignition off and pull Airbag fuse as well. http://forum.a8parts.co.uk/attachmen...1&d=1412280200 http://forum.a8parts.co.uk/attachmen...1&d=1412280200 Ideally you don't want to disconnect the airbag so turn the wheel upside down by 180degrees for this install After dropping the airbag down so it sits on the steering wheel, pull the plastic ring out, be careful to not put to much force and possibly damage the airbag wiring. Hold the airbag with one hand to prevent falling off the steering wheel. There are four pins holding the plastic trim. http://forum.a8parts.co.uk/attachmen...1&d=1412280511 Next slide out the steering wheel buttons to gain access to 2x small standard torx screws, but before removing them unplug the paddles connectors from the side of each button. http://forum.a8parts.co.uk/attachmen...1&d=1412280886 http://forum.a8parts.co.uk/attachmen...1&d=1412280886 Remove the paddles from the steering wheel. Next grab a thin flat head screwdriver and through the slot behind the paddle push securing pin out. Pull the pin out with pliers in order to separate the paddle from the base. http://forum.a8parts.co.uk/attachmen...1&d=1412281087 http://forum.a8parts.co.uk/attachmen...1&d=1412281087 http://forum.a8parts.co.uk/attachmen...1&d=1412281087 Before you install new paddle, shave off with a stanley knife a tiny bit of plastic from each securing brackets on both sides. I found this to be the only issue with this install. http://forum.a8parts.co.uk/attachmen...1&d=1412281524 http://forum.a8parts.co.uk/attachmen...1&d=1412281524 Fit new paddles onto the base and push the pin all the way back until it clips in. If it sticks out a bit that means it's not fully in. Here is your new paddle ready to fit back in onto the steering wheel. http://forum.a8parts.co.uk/attachmen...1&d=1412281695 http://forum.a8parts.co.uk/attachmen...1&d=1412281695 http://forum.a8parts.co.uk/attachmen...1&d=1412281695 Refit everything back together in revers order. And here they are. So much better feel than the plastic ones. You will almost always find them no matter how you hold the wheel, almost ;) The actual gear change feels so much better, no more that plastic noise and feeling, so much better. Really pleased with them, plus the Polished Clear finish matches interior chromes very well. They are really comfortable and very quiet +++ http://forum.a8parts.co.uk/attachmen...1&d=1412282136 http://forum.a8parts.co.uk/attachmen...1&d=1412282136 http://forum.a8parts.co.uk/attachmen...1&d=1412282136 http://forum.a8parts.co.uk/attachmen...1&d=1412282136 http://forum.a8parts.co.uk/attachmen...1&d=1412282136 http://forum.a8parts.co.uk/attachmen...1&d=1412282136 http://forum.a8parts.co.uk/attachmen...1&d=1412282136 |
Nice write up and they look nice too +++
Nice detail.....
So much so - A 3.7 with heated steering wheel ? For real ? +++ |
I'm trying to laugh from this all 3.7 comments, it is only 3.7 but it's mine :D
Own by me, not bank. Mechanically it's very good, gearbox is smooth as hell, has lots of gadgets missing, but heated seats all the way, aluminium pack, comfort seats, kessy, voice control, bluetooth, heated steering, wheels and windscreen :ROFL: and that's about it really. But few nice details added to it, at least in my opinion, like S8 grill, no S8 badge of course !!!, Bi-Xenon AFS headlights, not fully wired yet :o , and I love it +++ ahh, and a proper hand build exhaust which is not everyone's cup of tea, but I love it to bits. Remap done and gearbox remap is on the things to do soon as well so it's not that bad for a 7.3 :p |
Its a credit to the ranks of the ever growing and popular 3.7 - 7.3 division!! :D+++
Depiste the issues with the engine, its still the best colour on a A8.
Fact End, Mini adventure!! |
