Wanted: D3 Boot side trim securing pieces
Since I've had the D3, two of these have been missing. Currently my boot side trims (the ones with the screw heads securing them) have been held on by a single one on each side.
My side trims have the screw heads with the plastic all intact, but the pieces I am missing is the small plastic inserts that these go through on the car side of the carpet with the result that turning the screw does nothing at all. I suspect they will be just a few pence, if only I can find a source. Cant even get a part number from ETKA they are so insignificant. |
4E0863997A Clip and screw bit.
