-   D3 - Lights (https://forum.a8parts.co.uk/forumdisplay.php?f=48)
-   -   Cornering lights not working (https://forum.a8parts.co.uk/showthread.php?t=9532)
TTB 9th February 2015 08:29 PM
Hi Guys,
I'm 6 weeks into A8 ownership and this forum has been a massive help (thanks for all the good tips). I bought my 2006 4.2 TDI with a few known issues, and I'm slowly chipping away at them with the help of forum - but one new issue has left me stumped...
My car has xenon lights, next to the xenons are some H7 corning lights, and then inboard from them is a P21W reversing bulb that gets used as a daylight running light. These H7 corning lights just never ever come on - not at speed, reversing, cornering, indicating...
I connected VCDS (official Hex+Can version) and cannot connect to the following modules:
[29] left light
[39] right light
[55] headlight range
[49] automatic light
But I can connect to and retrieve the coding for the following modules:
[09] cent. elect. - Coded as 0143121
[4F] cent. electr. II - Coded as 0010101
I wanted to enable showroom mode, but cannot without module 55.
Does anyone know what coding I need to be able to activate these corning lights, or am I missing some hardware? Do I have AFS, and should these bulbs actually work? Option xx?xxxx #4 seems to be the only module [09] coding where the P21W's and xenons work as expected.
Many Thanks
Simon
Delboy 10th February 2015 05:03 AM
Mmi sounds like a strange one that,
If there is no warning lights on the dis for headlights then I suspect someone's coded the car to the most basic lights available so to prevent warnings.
You would help others help you by posting a full scan and also try to confirm the headlights fitted to the car.
TTB 10th February 2015 07:13 AM
Thanks Delboy,
I ran a scan this morning. I have a hole in the air-con radiator and a duff locking button on the passenger door, so faults on modules [08] and [52] can be ignored (I'll get round to fixing them eventually).
VCDS Version: Release 14.10.1
Data version: 20150130
Tuesday,10,February,2015,07:18:43:59507
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 34 36 37
38 42 46 47 4F 52 53 56 61 62 67 72 76 77
VIN: WAUZZZ4E86N014230 Mileage: 118880km-73868miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 4E1 910 409 A HW: 4E1 907 409
Component: 4.2L V8TDI G000AGMª0080
Revision: --H01--- Serial number: AUX3Z0E9377314
Coding: 0011773
Shop #: WSC 00262 210 89202
VCID: 22411C43FD278231584-8077
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 P HW: 09E 927 156 B
Component: AG6 09E 4,2lTDI RdW 0030
Revision: --H01--- Serial number: 0070989
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 3065E60BA3CB20A1DE0-8065
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H08 0160
Revision: 01604808 Serial number: AUX3Z0E9377314
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58B57EABEBFB18E1760-800D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00000 785 00200
VCID: 244D1A5BE7338C012A8-8071
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000079316
Coding: 1071107
VCID: 1C3D22BBDF43B4C1928-8049
1 Fault Found:
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 48
Reset counter: 100
Mileage: 113862 km
Time Indication: 0
Date: 2014.10.11
Time: 16:33:35
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H13 0210
Coding: 0143121
Shop #: WSC 00124 012 00001
VCID: 3163E30FA8C129A9D1E-8064
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000035
Shop #: WSC 00124
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 00124
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI G000AGSª0080
Revision: --H05--- Serial number: AUX3Z0E9377314
Coding: 0011773
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H12 3610
Revision: 91H12360 Serial number: 0037P000928B
Coding: 0431707
VCID: 27570D57960567190FA-8072
Subsystem 1 - Serial number: 63328RB400BBE4CE1
Subsystem 2 - Serial number: 63428RB400BBE43CY
Subsystem 3 - Serial number: 63528RB400BBE4F1-
Subsystem 4 - Serial number: 63628RB400BBE48F1
Subsystem 5 - Serial number: 63729RB400BD4759W
Subsystem 6 - Serial number: 63829RB400BD4748V
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112041
VCID: 65CB475FAC89B509FD6-8030
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 P HW: 4E0 920 950 P
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3EN000463
Coding: 0000403
Shop #: WSC 12345 123 45725
1 Fault Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0110
Revision: 0000000C Serial number: 00000009006406
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A3124A3D577CAF1804-804F
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 2000305B03808A
Coding: FCFEDBDE2B7104
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE8006009
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 28550E6B9B1B6861060-807D
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063338
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H46 0850
Revision: 00000000 Serial number: 364KU057502942
VCID: 3B7FC1277A8DD3F97B2-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000529100023
Coding: 0035968
VCID: 1D3B2FBFC459BDC9656-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM003 0100
Coding: 0028462
VCID: 2045164BF32B90214E0-8075
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040511020043
Coding: 0004317
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 J HW: 4E0 035 223 D
Component: Amp.-Basis H41 0120
Revision: 00000000 Serial number: 00000057506086
Coding: 0000013
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000072676
Coding: 0010101
VCID: 1E3928B3C95FA6D17CC-804B
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM003 0100
Coding: 0028462
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 94
Mileage: 118656 km
Time Indication: 0
Date: 2015.02.04
Time: 03:40:36
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0001031
VCID: 1F4715B7CE55AFD977A-804A
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 304KU057610948
Coding: 0000001
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000004422
Shop #: WSC 00778 210 53857
Subsystem 1 - Part No: 4E0 915 105
Component: von VA0 YT04155094
Coding: 344530393135313035202056413059543034313535303934
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0028462
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000511030062
Shop #: WSC 12336 024 394758
VCID: 3669D01341AF0E9184C-8063
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0028462
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720528501120
Coding: 0201108
VCID: 234F1947E23D8B39532-8076
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 F HW: 4E0 862 335
Component: Handyvorb2 H13 0580
Revision: 00000000 Serial number: 00000007589448
Coding: 0010900
VCID: 254B075FEC0975093D6-8070
End-------------------------(Elapsed Time: 03:00)--------------------------
I also took a photo of the headlamp unit from the outside to help with identification. It's currently coded as "bi-xenon with Halogen P21W and AFS"
https://lh6.googleusercontent.com/-Y...210_074836.jpg
Many Thanks
Simon
snapdragon 13th February 2015 05:39 PM
Check into 19 - CAN Gateway
Check the Installation list and make sure 55 (and every other module you have) is is ticked
The cornering light is 35W H8 bulb)
TTB 17th February 2015 11:10 AM
Thanks Snapdragon,
I activated module 55 in the CAN Gateway, but VCDS won't connect to it - neither during the full system scan or by connecting directly to the module. I suspect the controller is either dead or not physically installed.
Does anyone know where it should be located in the car? I think I need to hunt for it and see what I find.
Many Thanks
Simon
snapdragon 17th February 2015 04:45 PM
I *think* There is a box on the back of each headlight that looks like a xenon ballast but is actually for the cornering light - I *think* it may be the cornering light controller but not sure if it is 55 itself or something between 55 and the bulb as you would only expect one 55 and not two.
IT 20th February 2015 12:03 PM
It looks like a xenon plus with AFS to me....
The early version of these cornering bulbs (pre facelift) did come on when reversing, the later big grill versions do not. They wont do anything when indicating either iirc.
They only work at slow speeds going round corners, moving slowly round a corner out of a driveway for example. I don't recall seeing them work at any other time for a long time, never on big grill cars anyway. The APS swivelling lights system is so much more better and subtle I think Audi sort of stopped the cornering lights from doing much, plus who wants a nasty orange halogen polluting their nice Xenon beam ? +++
