Old 5th October 2015, 08:31 AM
This is a scan from the car this morning, after I reset the codes yesterday morning.
Car started fine this morning, keyless entry was dead as was the alarm. The door light had stopped flashing by 10PM last night. Battery meter had 2 bars showing
This morning I checked the measuring blocks, and when the engine is switched off and everything else off but the car still "Awake" it was taking 8A from the battery, so it obviously does this until it goes to sleep. At some point I'll need to check the sleep current.
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Control Module Part Number: 4E0 910 181 A HW: 4E0 915 181
Component and/or Version: ENERGIEMANAGER H02 0230
Software Coding:
Work Shop Code: WSC 00217 217 52026
Additional Info: 000915105AK von VA0 1308220489
Additional Info: Geraet 52026
VCID: 1E37DA4BB027
4 Faults Found:
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Mileage: 235641 km
Time Indication: 0
Date: 2015.10.04
Time: 12:36:55
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Mileage: 235641 km
Time Indication: 0
Date: 2015.10.04
Time: 12:37:05
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Mileage: 235641 km
Time Indication: 0
Date: 2015.10.04
Time: 12:37:15
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Mileage: 235641 km
Time Indication: 0
Date: 2015.10.04
Time: 12:37:25
