Old 5th October 2015, 10:13 AM
47p2's Avatar
47p2 47p2 is offline
It takes between 20-30 minutes for the system to 'go to sleep' after everything is switched off. Opening a door awakens the system again, turning on certain switches awakens the system again, opening the boot awakens the system again if you see where I'm coming from. If you require the door to be open to check the drainage then you need to open it and leave it open for half an hour before checking... Hope this helps
Nite Blue 3.0L SE Quattro
