Old 7th October 2015, 07:26 PM
Wet them with warm water before removing is what I did on other VAG cars. I assume its the same with a sort of serrated rubber edging. The Passat ones were aluminium so you had to be really careful not to bend them as they would never sit right or stay in the full length if you did. I don't know if the D3 are aluminium or plastic.
