Old 28th October 2015, 12:23 PM
Originally Posted by oldnick View Post
your ....will they fit ....site is almost certainly wrong , presuming your current fitment is OE ...are you sure of that ?
Current setup is definite as I checked the spare for details, as it's never been used.
They will look rather small on 8, they are the size you would use on A4 or A6.
Seller said they came off an A6, so that would explain that.
I would either look for another wheels or budget for another set of tyres, you can always sell the tyres that are on the wheels at the moment to recoup some of the costs.
Something I had thought about, but ultimately adds to the cost. Since the tyres are all the same and with only a few thousand miles on them, they may be easier to sell on, but it will all depend on what I can get the set for. There will always be others available.
You will loose 17mm ride hight, get a little more stability around the corners, gain a little in acceleration and loose a bit in economy.
Never realised how much a different tyre affected a car. Learn something new every day.
