I've still not got this sorted, problem seems to be getting worse though so I need to as soon as I can get the blower controller.
Symptoms,
Fan runs perfectly fine 90% of the time but the other 10% the fan runs at about 60-70% output and you have no control over it at all. Even turning off the HVAC completely the heater fan will continue to run until the engine is switched off.
At least the heat/cooling still works, its just annoying because you end up with a short period of overheating or cooling the interior.
