it may have been the tuner one i used, dont forget its intelligent, if you turn of the engine then manually turn on the mmi get out and lock the mmi (and tuner deactivate after several minutes, its not going of with the ignition but a couple of minutes on wont hurt.
test it out first obviosly things change depending on what a car has installed
