Old 25th November 2015, 09:18 PM
Johnmed's Avatar
Johnmed Johnmed is offline
They should be fine john yes, but if you have the full spec on current wheel and tyres including ET and tyre sizes and then new spec on these wheels it will be easier to tell what the exact outcome will be with regard to overall rolling radius and the "poke" in or out of the new wheels vs old arch-wise.
The only thing you might find is that you may need spigot rings as the centre bore size is often 66.1 on newer Audi wheels rather than the current 57mm of the existing wheels. If you need spigot rings then make sure you use metal ones rather than plastic as they are much better.
Thanks for that. I don't have the necessary details unfortunately
2007 Mini Cooper S R56
