Thread: She's home
Old 7th December 2015, 09:06 AM
Things are on the up. I've done best part of a thousand, surprisingly pleasant miles in her, also squeezed in some basics:
Oil flush / oil filter / spark plugs / fuel filter / pollen filter / air filter change
Balanced the wheels
A/C regas
New wipers
Also swapped all 8 coil packs which made a huge difference to the engine wobble. Checked the timing also and its bang on, which is good.
Intermittent PDC annoyance has gone away since I removed a mm of paint that was overlapping the front far right sensor. Nice easy win
I've ordered (and actually received) the replacement bracket from Audi that holds the rear armrest on. I really expected that to be unavailable but was lucky
Also got all the door card clips to sort the doors, but first the door glass will all be changed for twin pane heat and reflective to match the heated windscreen that will be replaced and connected shortly....
Since regassing the A/C though it has highlighted the climate is in a bit of a muddle. There's definitely at least one broken flap motor which is sending hot air where it shouldn't. Should be easy to sort once the interior is out..
Immediate job is to swap the engine ECU - The current ECU has almost certainly been fiddled with. It shows no errors. At all. Not even low oil, and many measuring blocks are absent. The remaining bit of wobble on the engine I suspect is a lambda off on one bank, but the ECU tells me nothing....
The power output is already up massively from a full service and the coil packs and its a pretty pleasant and pokey drive now. If I can get a smooth idle I'll be well chuffed.
Then it'll be onto the interior sort out, which shouldn't take long really, just a strip clean and refit with couple of minor fixes....
