Old 7th December 2015, 07:16 PM
2. The pin mechanism on the floor
3. The drive motor somewhere in the battery compartment
These are actually the same part, £ to a penny this is the issue. Plastic gears in the motor will be stripped, new on was not that pricey from memory. Fitted under the battery, cable routed under the plastic trim to the latch, easy to change
Found a new one on ebay http://www.ebay.co.uk/itm/Audi-A8-D3...-/111782026395
