Old 8th December 2015, 03:16 PM
Actuation of heated rear window at temperatures below 0 °C stays on with no time limit until shut off at temperatures above 0 °C it is shut off after approx. 10 min.
Above 0 °C the rear heated screen is controlled by a complex algorithm of outside ambient temp, internal temp and humidity, and energy management.
So if mine is staying on only for 2 minutes or so then which component isn't functioning correctly and are there any tests on VAGcom to confirm this?
