Originally Posted by Mechcanico Lee
If bank 2 is cylinders 5 6 7 8 and camshaft B is also bank 2 i think its a mad coincidence that all coils can go down on one bank .
If the cam stayed advanced on that bank the whole bank will run rough and cylinder missfire detection count will be triggered , looking at the orginal codes cylinder 7 is not there .......bit strange but i would follow the codes for that cam position .
Swap coil sticks from one bank to the other , if the codes stay on 5 6 7 8 sort of proves its not the coils , if it transfers ..... yes sounds like coils
Also when running in vcds data blocks you can see where cam advance is by means of degrees , if it has a cam sensor on every cam this is good because you could see all 4 cams ......some quad cam stuff only have a cam sensor on one cam per bank ....so for instance the exhaust cam could be stuck advanced but the sensor is on the inlet so the managment wouldnt see it .
Thanks, my thoughts were it wasn't necessarily coil pack related given that the fault started on Sunday with faults on advanced timing (P0024) and cylinders 5 & 8 but then went away after resetting and restarting car (and ran fine for a day and a bit) and then only came back last night with faults on three cylinders, all on the same bank as the over advanced fault.
Good call on the switching coil packs between banks, certainly better than 'guessing' at coil packs at £35 each! I'll mention it to the garage tomorrow and if they don't agree to try that I'll just get on my bike and wait until my local garage is free!
