Let it stand for a couple of days then scan battery regulation again and see what SOC is and battery voltage is .
I assume when you scanned ignition was on and maybe other consumers as you can see the -19 .6 amp draw from the battery so batt volts will drop somewhat .
If you wanted to check true batt volts , latch boot lock over ,stick volt meter on batt and lock car and let it go to sleep ..... 10 mins or so let's say , then see what volts are , you could do same test after a day or so and see if battery is staying good
