Thread: She's home
  #38
Old 22nd December 2015, 08:23 AM
Immediate job is to swap the engine ECU - The current ECU has almost certainly been fiddled with. It shows no errors. At all. Not even low oil, and many measuring blocks are absent. The remaining bit of wobble on the engine I suspect is a lambda off on one bank, but the ECU tells me nothing....
Well, swapped the Engine ECU, and made absolutely no different to anything. Well, ok, thats not strictly true. As I also had to swap the cluster, and now the faulty fuel gauge works perfectly, which has saved me fiddling around removing the gas tank to change fuel senders
Quite an interesting result that the original ECU was operating fine it seems. Also fitted 8 brand new coil packs and still suffering a slight wobble / hiccup. Guess Lambdas are the next item to check out....
