Old 26th December 2015, 08:43 AM
No, it won't be that.
My D2 had a faulty switch on the lever and all it does is control the warning light on the dash, no bongs or connection to anything else whatsoever.
It's a very simple circuit with a normally-closed pushbutton mechanical switch that is pressed open when the lever is lowered.
Bit of a pig to get at and replace so I (eventually) rerouted the wires on mine and fitted a sealed reed switch and magnet arrangement, as used in door/window open sensors in domestic alarms. Works fine after a bit of adjustment.
Sounds more like the brake pad wear warning.
