Old 2nd January 2016, 02:21 PM
harvmiester17 harvmiester17 is offline
You can fit that tow bar and use standard single or twin electric sockets. All you need to do then is put the car in towing mode manually. I did this with mine using an original Audi tow bar and it all works perfectly. It's also handy having the battery in the boot for the wiring. You will need a 7 way bypass relay for the lights which will prevent any issues with the cars lighting system but it's a doddle to fit.
