View Single Post
Old 4th January 2016, 07:56 PM
maj maj is offline
Swirl flaps is the only issue you'll see on the 3.0 Tdi. Over time, at about 120K+ the plastic components will eventually wear. Budget circa £400 per bank to resolve, but that is about the only 'common' fault to mention in an otherwise bulletproof engine.
Not the dreaded swirl flaps again!! I was heavily advised to have the swirl flaps removed on my 530d aswell. After 7 years of ownership, I invested in a Stainless steel down pipe, d EGR bypass valve and few other bits and pieces, but swirl flaps are still there. Engine still going strong.... *touchwood*
