Old 5th January 2016, 09:09 AM
g-black g-black is offline
Update. Still no fault codes showing on VCDS, so found the measuring block in 001 for rear sensors. The inside rights sensors nearly always shows 0cm, but so times it will work and show 255cm and change as I reverse closer to something.
Will this be a wiring issue, or just a replacement sensor? Taking the bumper off sometime soon to have the exhaust tips painted and a dent removed so would be handy to have a replacement sensor then
