and here is the armrest installed with 4 bolts, 2 at the bottom and 2 at the top. Note that the seat frames are now fully installed and fastened down with the 'boomerang' in place to hold the center box down firmly....
This photo is poor, but I'm not taking it back out to reshoot it
The top trim is from a normal car, and the bottom one from a car with individual seats - It has a layer of material glued to it that will let the seats slide up and down without rubbing on the plastic. Tough to see in the photos, sorry... !
That side trim is installed, and then in goes the first seat. No action shot of the seat install as its a 2 man job, and I was on my own, so I was a man down before I started to think about photography... !
They install / remove in the most reclined position as they are ultimately held in by 2 x M10 nuts underneath the front edge, which cant be accessed when they are retracted...
Heres a better photo of the progress... Look at the spaghetti in the middle to sort out, and thats with only one seat in ! In this shot you can see the two holes at the front of the seat frame where the lugs drop in to secure the seat with 2 x M10 nuts....
Also note the seatbelt is now present. After installing the seat, I discovered the seatbelt needing bolting in first <doh> so out it came again, and then back in again....
But knowing all this made the other side go in so much quicker, how good is that looking now ?
Spaghetti all sorted and clipped into its rightful homes. All functions tested and everything works... <phew>. Airbags also connected, and they didnt go off so thats got to be a good thing....
and so on goes the top cover on the center and it looks like a regular rear sport bench, until you clap eyes on all those buttons down the side
And here is the rear seat bench with one seat out to show its relitive position....
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
