Old 17th January 2016, 11:52 AM
One problem is that the 402 is GPS capable but the heated screen effectively shields the unit from the signal and it wont synch with the satellites.
Odd that it isn't syncing with the satellites. I have the heated windscreen as well, and since you know that your unit works in your motorhome, I'm wondering if it's the position on the windscreen. If you look at the image I posted at the very start, I have the camera mounted right at the top of the windscreen. I keep meaning to move it down an inch or two, as the tint dulls the nighttime footage. I can't honestly say that mine gets 100% GPS signal, but there are always stacks of GPS data files.
