Old 20th January 2016, 11:07 AM
ulfilias ulfilias is offline
Default Drivers Door Hinge Change?
Hi There,
My PF D3 has a slump on the drivers door, it means that it is not quite sealing on the window trims and you get wind noise which is irksome. Also ruins the lines a bit.
Opening the door full and there is play when you wobble it. Speaking to a mechanic friend he thinks it is the upper pin which has slop in it. He was saying he thought to replace the hinge it's a bumper/headlight/wing off situation and not a quick or easy job.
Anyone with any experience of this ?
He also wondered about knocking the pin out and getting a bigger one turned up by a local machine shop as another potential fix?
Lee
