I use the "Set Up" button on the HVAC control.
Rotate the right hand knob to select "Aux Heater On" and the Webasto fires up.
Snap, I'll try your way on Sunday. I have an early start in the bus and nobody else will need the car.
When I use the timer the Webasto fires but does not "toasty" the car, but the engine and heater seems to do the warm up much quicker. But then that is what the Aux Heater is for, until you add the extra pump and plumbing.
Nothing to do with this thread/forum but I have a night heater under the bus and this operates on it's own timer but all it does is blow a small amount of warm air into the bus. It makes ice on the windows much softer that then clears with the wipers. Certainly takes the edge of the temperature. In a smaller vehicle/cab it would be good.
