Old 6th February 2016, 10:04 AM
I have seen the epc light come on with no fault codes on some Skoda models , Octavias mainly , on them it has been battery issues ,some kind of low voltage spike , they start ok not like lazy or anything so you would not think it was a battery issue but residual voltage must drop a little low and the ecm just throws a wobbler on the start up
I see you say your car has had a new battery already so you would think it should be ok , could it have a small drain just pulling it down a little .
Do you have a battery charger , just as a tester could you run an extension lead into the boot and leave it on a trickle charge just to see if the light still comes on at the cold start , it's something to rule out even if it's not the issue.
