Originally Posted by Ian@A8Parts
its a long shot, but self levelling (hydraulic) suspension was an option on the non-sport A8's.
If you had it, and it had developed some weird fault with the valve wedged open, it could explain the fact that both sides have been affected? Otherwise, the suspension on both sides is totally independent...
The build codes on your buidl sticker in the spare wheel well or service book would reveal what you have fitted....
Arse.
1BN = Suspension/shock absorption, automatic level control system
I suspect this is one option I didn't want to have. Is it possible to replace this with standard suspension or am I looking at an expensive trip to Audi- And moreover will this raise a fault code on Vagcom?
