Old 11th February 2016, 03:01 PM
Depends on the model, but some do require headlight removal to get proper access, and some require bumper off before the headlights come out. Even on the V10 I think you can avoid that with removal of airboxes and a bracket or 2 to get to the back of them.
If that cost includes a couple of OEM gas discharge headlights it's actually not that unreasonable. They're usually a fair wack. If that's just labour then it's certainly a bit chunky!
If headlights come out they should always be realigned - had mine done properly after refurbishing the headlights as I'd had them out and in bits!
