12th February 2016, 09:05 PM
Originally Posted by audis8tui
That I haven't tried, my new piston will be here Wednesday and I will check that. The con rod looks good with no damage to bearing.
I do have another issue with the car which I was going to deal with after the engine is fitted, there is a misfire on start up for 4 mins on the same bank, I forget the code but it tells me low fuel pressure on all 5 cylinders.
After 4 mins all good and I can leave the car all day and it doesn't return but left over night its back.
Leak on the HP fuel pump on that bank???
