The sport has actually has 3 ride heights!
Automatic / Dynamic are both the same height (-20mm) and both lower 5mm on the motorway (-25mm)
Comfort is the same height but doesn't lower on the motorway (-20mm)
Lift adds 25mm to the automatic level (so 5mm up)
The measurements are to the standard running gear (on Automatic & comfort)
You can also code in reductions (10-20mm iirc)on standard in VCDS, couldn't see why you could not add height there if you wanted?
Lee
