Originally Posted by Mechcanico Lee
Try this as a test , drive along with foot on accelerator ,with your left foot just rest on the brake pedal not enough to be braking but enough to bring brake lights on if you can see it in the window from the light in the back window .
Does it momentarily kind of kill the engines power , as I say your not braking but supplying the engine and abs ecu with the braking signal from the pedal switch , it may be nothing to do with your fault but have seen similar ' dead pedal ' issues when it's been the brake pedal switch right on the threshold of coming on whilst accelerator is being pressed ..
Clever, I'll try that.
Does your fault tend to do it after a period of braking / slowing down then getting back on the gas to accelerate again .
Yes, but not always.
Have you had it do it when you have let off the power but not done any braking then back on the gas pedal .
Not sure, but I think so.
Thanks for applying brain power and logic to this.
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".
(Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.
(internal dimming mirror added later)
