  #193
Old 29th February 2016, 04:36 PM
F125 can come and go - moving it to R or D will make it likely to come on. If you start a journey and get to D without triggering the fault it won't come on at all until you next move the gear selector
Be warned there's 2 types of switch with different plugs so order from TPS with VIN to make sure you get the right one. Costs about £150 IIRC and bit of hassle to fit as box needs to be dropped a little to access I think, so one exhaust pipe off from memory
If it's due a box service it makes sense to do at the same time as it'll save some labour
