  #198
Old 3rd March 2016, 07:42 AM
Mark, was that just the wiring plug (8-pin I believe) or did you remove the unit from the gearbox?
It can be done in situ, although on a ramp would help!
For an intermittent connection issue that appears unrelated to moving the gear selector, it'd be worth a try. If the symptoms seem to relate to movement of the gear selector it's more likely to be mechanical wear in the unit so no amount of cleaning the pins will help.
