I got the tank back in the boot the other day, but I've only just had chance to sort the wiring....
Its not hard, just 4 wires for mine - 1 pair go to the pressure sensor for how full the tank is, and the other pair go to the solenoid valve that lets gas out of the tank when the car is burning LPG. At all other times, this valve is closed preventing gas escaping. I believe it is also set to trip closed at a certain flow rate, so if you rip a gas line wide open the valve will close instead of letting it all out. The outlet is the thin pipe on the left with the solenoid, and the fill pipe in the larger one on the right. It has a one way valve that opens under pressure to fill and then closes with the back pressure so its safe. Note the substantial bracketry too. LPGA regulations dictate what g-force impact a car should sustain and have the gas tank still anchored in position in the car, and whilst the numbers escape me, its a big number so it needs to be sturdy. One of the problems with the spare wheel tanks is that the A8 has a fiber glass tub which isnt strong enough to bolt to, so it needs metal work fabricating from above and always ends up with an uneven floor.... anyway, I digress....
Photo of the wiring part done:
And here we have the job done, covers on and boot looking quite tidy compared to a few weeks ago:
and my new LPG control location, now lit up with some green showing we're burning the good (aka cheap) stuff
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
