Originally Posted by TP_
Could you guys explain CP?
CP removing?
What is CP?
Component protection.
Some ECU's in the car have it, some do not. It is designed to protect against theft as the ECU when first installed takes on the ID of the VIN of the car it is installed into.
If you move the ECU to another car, it knows its been moved, and will not work properly.
It will generally work as far as required for safety, but luxury goes out of the window.
e.g. A speedo would show the speed, but no DIS, revs etc.
A seat would adjust enough to make it safe to drive, but no heating, ventilation etc.
An amplifier will produce sound from only speaker.
Interestingly, it also applies to airbags, but not really sure how an airbag can do anything other than explode.... (!)
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
