Old 9th March 2016, 05:03 PM
Here are text files I pasted into Notes, so sorry I don't have the original sources, but it was Official Audi documentation.....
White smoke from the exhaust system and juddering when the engine runs at idle speed for some time - V6 TDI 2.7l / 3.0l TDI.
Technical background
Mechanical wear of the needle attachment of the injector leads to an increased fuel injection into the combustion chamber. The fuel is not completely burnt, which causes white smoke (unburnt fuel) or juddering when the engine runs at idle speed for some time.
This complaint occurs only on vehicles with more than 50,000 km.
Production change
Modified injectors from:
8E47A040360
4F37N026750
4EX7N004204
4L*7D049162
Measure
Try to reproduce the customer complaint so that it can be clearly assigned to this TPI. The following repair must only be carried out, if all the criteria (model/type, chassis number, engine/gearbox code, PR number(s), software version, code etc. ) match exactly. Otherwise this solution won't work and repeat repairs may be necessary. In such a case, we may reject the warranty claim and redebit the parts.
Read the measured value blocks 72 - 77.
3 values per measured value block appear there (for 300 bar, 600 bar, 1000 bar).
Should the values be higher than minus -45 ms (example - 60ms) or
on digit 2 be
higher than minus -15 ms (e.g. 20ms),
the needle attachment is worn and the injector is incorrect. To avoid repeat repairs, replace all 6 injectors.
>>>> Observe the algebraic sign (minus) in measured value block 72-77 !!!!! <<<<<
Warranty accounting instructions
Service number/damage code/manufacturer: 2340/010
After an overnight stationary period drive the vehicle with cold engine between 1200 - 1600 rpm till the complaint occurs. Constantly read the measured value block 13 and 14 for the smooth running control in the engine control unit. The values of one or several cylinders should noticeably move to positive.
modified injectors A8: with 3.0l, 4.2l TDI from: WAUZZZ4E*7N016685
Replace the injector with the highest deviation and all injectors produced between 1.3.2006 and 30.4.2006.
Example of production date: 060304 stands for 4.3.2006
vcds go to address 01 measured values below
013 Smooth running control
1)Cyl. 1 Injection quantity variation [mg/stroke]
2)Cyl. 2 Injection quantity variation [mg/stroke]
3)Cyl. 3 Injection quantity variation [mg/stroke]
4) Vacant
Permissible values at idle: +- 2,99 mg/stroke
A If the permissible tolerance is exceeded
first check injector IQA-IVA adaption values
014 Smooth running control
1)Cyl. 4 Injection quantity variation [mg/stroke]
2)Cyl. 5 Injection quantity variation [mg/stroke]
3)Cyl. 6 Injection quantity variation [mg/stroke]
4) Vacant
