Popped out to the car this morning to do a cold start as I just had all glow plugs replaced.
While I was at it I thought I would check blocks 13 and 14.
attached is my reading.
The post that Snap posted up says:
Permissible values at idle: +- 2,99 mg/stroke
A If the permissible tolerance is exceeded
first check injector IQA-IVA adaption values
I assume that means that they should be withn the range +2,99 and -2,99?
[center]
06 3.0TDI Quattro:
Options:
